Most of us are now aware that as of 12/2016 the API has now replaced the CJ-4 diesel engine oil requirements with CK-4 and there is much discussion about how this new oil is not approved for new Ford 6.7 Diesels. (There is a thread on the the 6.7 forum). One primary reason is the new rating limits the Phosphorus content from 1,000-ppm to no greater than 800-ppm to cut down on Greenhouse Gas.
According to Ford the lower Phosphorus content creates "wear concerns":
"In a presentation to the API Lubricants Group in Orlando, Fla., U.S.A., a Ford spokesman indicated Ford will not be recommending API CK-4 and FA-4 due to wear concerns. However, the previous category that preceded CK-4, API CJ-4, provides adequate wear protection for its diesel engines, Ford believes."
Back when my 2000 7.3 was made the diesel API was CH-4 which had higher levels of Ash, Sulphur & Phosphorous (which were all beneficial at lubricating) so every revision of the API moves further from the chemistry of what my engine was designed with. (Not to mention the introduction of ULSD which also removed lubrication advantages).
One positive note is the new CK-4 is advertised to have improved "shear stability" which is beneficial for our HEUI system.
I have read two Heavy-Duty Diesel oils are remaining CJ-4 with the higher Phosphorous content:
specific Amsoil and Mystik (Citgo) products.
I am interested in your opinions and solutions to the new CK-4 mandate.
