I just stumbled on to this thread and what a coincidence! Yesterday I filled my 2000 F250 CC at the local, high volume, truck stop. I like to fill it up good and full for more range. As I was topping off, a fellow nearby pointed out that fuel was leaking from underneath the truck. Sure enough, a pretty good drip, drip, was running off the top of the tank and making a nice puddle on the ground.
I started the truck up and immediately drove it to the Ford dealer across the street intending to have them look at it. I took another look and the leak had stopped. Since things looked pretty busy at the dealer and I had to be somewhere, I left.
Later, I crawled under the truck (the leak was still stopped) and it appears the leak was located on the top of the tank where the fuel lines go into the tank. The filler neck piping was dry.
So, it looks like the seal for the fuel pump/fuel lines/gauge unit is the culprit but I will have to investigate further with a mirror as I couldn't see very well. Do you suppose the new low sulphur fuel is the culprit?
I suppose the tank has to come out to fix this right? Of course it is full of fuel right now but it won't take long to getr' empty.
Mark Seaman
00 F250 CC 2wd 65,000 miles
