1 - 8 of 8 Posts
Or I know it as FIPL, god only knows if you know that I know you can call it this... What is it? Please tell me! I'm desperate to know!! Is it throttle position sensor, TPS short? Or is it some dark unknown name only whispered on the Ford plants as "you known the part that can't be named"? I need one but are parentlly out the league trying to order one when I don't know the name of it... "*sukk*". I have been everywhere on the net looking for it, but as you can figure out for yourself, I haven't found it yet coz I'm not perfectly sure of what I'm looking for, or the name of this dang thing. So can anyone help this lost norwegian soul to look right on the big dangerous internet.... no wonder they cal it the web, coz you be stuck in it soon enough!!!
/ubbthreads/images/graemlins/laugh.gif /ubbthreads/images/graemlins/biggrin.gif /ubbthreads/images/graemlins/smokin.gif
BillMark: Need help up here!
/ubbthreads/images/graemlins/biggrin.gif /ubbthreads/images/graemlins/grin.gif
Yes it was commonly known as a TPS on gassers......it is the black or grey item on the drivers side of the IP, has a connector with three wires.
A/T - E40D FIPL Sensor Trouble Shooting & Adjustment
TECHNICAL BULLETIN # 186A
TRANSMISSION: E4OD
SUBJECT: FIPL troubleshooting & adjustment procedures
APPLICATION: Ford
DATE: Jan 1994
E4OD
FIPL Trouble Shooting & Adjustment Procedures (Diesel Applications Only)
Poor transmission performance and/or premature transmission failure may be caused by a defective Fuel Injection Pump Lever (FIPL) sensor, or sensor signal. The sensor is located on the Fuel Injection Pump (Figure 1) and is used to inform the Transmission Control Unit Assembly (computer) of throttle position.
Ford Motor Company recommends that the FIPL be checked or replaced every 50,000 miles. However, it is possible for a FIPL sensor to fail at less than 50,000 miles. Therefore, it is highly recommended that you install a new "upgraded" FIPL sensor when a transmission overhaul is performed on any diesel applications.
You should also be aware that early design FIPL sensors are not as desirable as late design sensors.
Another potential concern is that the wiring harness leading to the FIPL sensor may be broken or shorted to ground. Closely inspect the harness where it is routed across the top of the engine to the FIPL sensor. The natural vibration of a diesel engine can easily wear through the wiring insulation where it contacts the engine, brackets, etc.
Note The voltage specification for signal return (item 2, page 2) was incorrect on the original bulletin. Remove original # 186 from your files and replace it with this revised bulletin. # 186A.
Note For testing and adjustment information see following information.
TESTING THE FIPL SENSOR
Note During these tests the negative lead of the voltmeter MUST be connected directly to the negative battery post and the computer and FIPL harnesses must not be disconnected.
1. Wire A is reference voltage sent to the sensor from the computer ORANGE/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be approximately 5 volts.
2. Wire B is the ground path from the FIPL sensor to the computer BLACK/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be volts .025 or less.
3. Wire C is the throttle opening signal sent to the computer from the FIPL sensor . TEST With the KEY ON, ENGINE OFF and the throttle at idle position, voltage should be approximately 1.2 volts. With The throttle fully open, voltage should be approximately 4.5 volts. ORANGE/WHITE (CENTER WIRE)
The sweep from 1.2 volts at idle to approximately 4.5 volts at full throttle should be smooth. A meter with a snapshot or min/max capture mode is useful to catch intermittent "opens".
If the previously described range cannot be attained, FIPL adjustment can be achieved by rotating the sensor (on its bracket) one way or the other until the voltage values are satisfactory.
DIESEL FIPL SENSOR INFO
DATE 1992
REASON
Early Black FIPL has High Failure Rate
RECOMMENDATION
Always replace the black colored early FIPL or any colored FIPL having 60 thousand or more miles with the late gray colored FIPL.
PART NUMBER
F2TZ-9B989-C
Any parts store would call it a "TPS". Heck, that's what I call it.
It's just that since our diesels don't technically have throttles, you can't TECHNICALLY have a throttle sensor.
Thanks guys, that helps alot, as allways! /ubbthreads/images/graemlins/laugh.gif /ubbthreads/images/graemlins/biggrin.gif /ubbthreads/images/graemlins/laugh.gif
Like I said: "the part that must not be named"..... /ubbthreads/images/graemlins/biggrin.gif
Thanks. /ubbthreads/images/graemlins/biggrin.gif
I concur with what Pete has posted. "As always" this site has the information at no cost. For me my truck is a life style, not a choice. I can afford to drive whatever I want but I like the simple mechanical systems that I can fix almost anywhere. Now if the wife would shift for herself I'd be doing fine as a gear rower....
Just because we drive diesels did we forget about gas engines. The part on the throttle body of a gas engine is the tps so way wouldn't it be the same on a diesel. I asked my parts guy for a fipl for the humor to see if he knew the part name as a fipl and he said, "What was that". I then said a tps and he knew right the rip. It goes for 38 dollars at Advance Auto Parts.
I believe that the FIPL sensor is the same part that IS a TPS for certain models and years of the Ford Ranger, but I'm not sure which ones.
1 - 8 of 8 Posts
