Coming back home at the speed of 71 mph. Tach was at 2250 approx. All guages reading ok. All fluids checked at home after this problem. About 12 miles out the engine CEL came on. engine started missfiring so I said it is the UVC harness problem. Had to get it home because I hate 105* heat. At the off ramp I let it come to approx. 20 mph and the CEL went off and everything became normal again. Engine behaved as normal. Got home and performed the smell test which was negative from my sniffer. I am thinking a replacement of both gaskets and a new set of UVC harnesses. Any thoughts from the forum. About codes: how long do the codes stay in the computer? Does anyone perform a code check for free? [I am cheap sometimes]. I am driving it to work in the AM so I will try this again.
Thoughts anyone. /ubbthreads/images/graemlins/shrug.gif
