My 2001 7.3L starts and runs good except once in a while, I go to step on the throttle and the throttle doesn't do much except all of a sudden I hear the injectors RAP up and then it takes off. When codes are examined, I get a P1211 "ICP Pressure Is Above/Below Desired". I have already replaced the ICP with a good factory one. The old one previously went bad and I had to drive home with it disconnected.
I am guessing the only other thing it could be is a sticking IPR. It really doesn't happen only rarely. I have driven it for a few days and it has been ok. Then another day, it did it 3 times in a hour or two. Looking for some suggestions or if I replaced the IPR, is that the likely culprit?
Thanks, Dennis
Thanks, Dennis
