Help Please.
Are there any fuses to check? The Driver M does not show any and my CD of Fords Repair Manual is at home. It will go with me next time. If someone would be so kind and check.
I started having tps issues last week and could release the Throttle and recover. Having read some posts I bought some contact cleaner at Napa and when I got to the National Park out on an Island south of Pensacola, FL I removed the peddle and drilled a small hole in the end of the side. Left out in the sun to dry and noticed the side at the seam bulge maybe 1/16". Pushed it back together and reinstalled.
Yesterday on my first drive it worked better than ever. No dead spot when first pressing - it has always been that way.
But today idled out of the campground and when I pressed the peddle Nothing. Idled back to the 5er and removed the peddle and the seam was seperated again. Placed a bead of super glue and duct tape. Reinstalled and still nothing.
Checked the codes and: P0122 "Throttle Position (TP) Circuit Low Input"
P0221 "Throttle Switch B Circuit Performance" (Which I had when the problem started). Cleared the codes and started eng again No RPM increase and codes back.
So has anyone taken these TPS's apart and I am thinking that the spring would make it impossable. Any other Ideas.
Sorry so lengthy
2000 f250 7.3
Sorry so lengthy
2000 f250 7.3
