1 - 8 of 8 Posts
the tires that are on there now are 265/75/16's....
How much taller or bigger of a tire can I put on there without having to change wheels?
Looking for the largest size tire I can put on that wheel without any rubbing problems?
Can I go up to 295 / ?? / ? etc.
Any update? What tire size did you get? I'm thinking of getting 285/75/16 ironman tires since my rig doesn't have a lift. I have heard that 305/70/16 can be fitted but they are wider.
I have 285/75/16 tires with zero issue and room to spare. Stock height and no lift.
Personally, I have no use foe a wider tire 70-series. Why go wider? All it does is look foolish sticking out the side and it sprays up on other vehicles behind.
Each tire manufacturer publishes acceptable rim widths for their tire sizes...
Why do you want bigger tires? Please choose a tire size that's right for your tires. Some sizes that fit your F-350 that you might consider are:
LT245 / 75R17
LT265 / 70R17
LT275 / 65R18
LT275 / 70R18
LT275 / 65R20
Hope this can help you Top 10 Best Tires for Ford F350 Super Duty: Recommended & Reviews - Tire Deets
Thanks for your excellent post.
However, he stated that he did not want to change wheels, which means that that it will have to be a 16 inch tire to fit his 16 inch wheels.
1 - 8 of 8 Posts
