What tire pressure do you guys run in your front tires? I have 295 BFG AT's Max psi is 65, I would like to get max mileage and economy.
I usually run 65 or 70 psi up front and 50-55 in the back.
DENNY
i have 285/75-16 on stock rims and have found that 52psi fr and 45 psi rr (unloaded) has given me the best wear.
I suggest using a chalk test. You put a 1" stripe across the tire and drive it 20 yards or so to wear off the chalk.If it wears evenly across the tire---you're OK. For front tires it is a good idea to turn slightly to get a normal wearing pattern. I found that 75 was right for my Ford 6.0. which weighs 7380 and is pretty heavy in the front. Back tires came out to 55. I have E rated tires 265/70/17.
If you have them mounted on stock rims, you'll have to run lower pressures to get even wear. I run 42 (front) and 32(rear/unloaded) with 295 Toyos and stock rims in order to get semi-even wear. I know that the BFGs have stiffer tread plies so they might stand a little more pressure than the Toyos. I'm contemplating going to a 9" rim in order to be able to air mine up for better fuel mileage. At the current price of diesel, every little improvement will help ofset the cost of the new rims.
I have 33x12.5x16.5 BFGs and the best ride/wear/steering I get is about 47 lbs in front and 45 in back.
I have the factory LT 275/65R 20" E tire's.Half of my driving is with a trailer or some weight in bed.I run 80 psi in front and 70 psi in rear.Empty my front axle is 4860 lbs and rear is 3300 lbs.Just rotated tires at 10k and seem to be wearing fine.
