i know this subject is batted around alot... i'm debating on changing the tranny fluid. i've got 188k on the ride, had the tranny flushed at 100k. seems to work fine, had a transmission guy tell me to leave it alone until it dies...said the detergents in the new fluid might churn up junk. i just started towing a 11k fifth wheel and am concerned that no maint. might not be good. what do you think? drop the pan and change the fluid?
188K?, 88K between changes? What usage have you had and what fluid were you running? Gages, run it hot ever? Also the last "change" was it a full flush or just a pan drop and pan fill? All these things play a part in it, the decision. I think that your load has made the decision for you, need to flush, twice. Once to clean it out then shortly after to clean up any loosened materials. But, at ANY rate, if the trans lasts another 100K that would be good, if it went tomorrow you have had more miles on yours than many get that were maintained more often than you have done. You are approaching or into a range that just getting it rebuilt would not be a bad idea anyway, probably not much life left in it anyway with the minimal maintenance you have done. And your load, that 11K fifth wheel, is the deciding factor, want to be on the side of the road or pulling it down the road? Me, I if the rest of the truck was in good shape I would get a BTS trans build and never worry about it again.
