I just joined this forum but iv'e been reading all the good info here and cant really find the answer. A year ago purchased an 08 F-450 6.4 been fine till the other day the EGR cooler is leaking i want to delete the EGR valve and cooler but my state has emmissions is there a way to block off the EGR valve without removeing the valve itself ? and can i block the flow of coolant and not remove the cooler? and in doing so will this turn on the engine light. basically i want to block it off but make it look like its still there.
you can block the EGR, yes... stainless plates that sandwich into the flange joints on both sides... but you need a programmer to 'turn off' the EGR.
it would take a really sharp inspector to see the mod... and they ain't getting paid to do that or expend the effort, anyway, so, you'll be alright.
