I took out my transmission because the torque converter went out or so I think it has play from side to side and I was wondering if this is normal I know it has to have play back and forth but I could wiggle it with My hands when it's sitting on the input shaft so I'm wondering if this is normal
I don't think its locked into the pump on the transmission. You need to rotate the converter until it goes in to the pump You will feel it go in. The face of the converter needs to be inside of the bell housing. it needs to be in side far enough for the flex plate to bolt up to the converter The converter is a solid fit once into the pump
