What is the lug nut torque sequence for a 94 F350 and are the front lug nuts torqued to the same ft lbs as the back?
180* then 90* from the last one, then 180*, then 90*, then 180* then 90*, then 180* then 90* I tried to draw you a diagram, but I didn't know how to make it come out right when I posted it. Basically, tighten directly across from the first one, then skip one nut, and tighten the two opposing, then skip one (which should already be tight) and tighten the two opposing, and so on.
Like Oldrebuiltdodge posted and it applies to most any vehicle:
And you might check further, I'm almost sure the torque in the chart is wrong, it's something like 110ft.lbs. at the most IIRC.
Thanks for the help! :)
