I'm replacing tie rod ends and upper and lower ball joints on a 2005 F350 Superduty. Needing torque specs for both.
For the ball joints, use the torque specs and sequence with the install instructions. Moog includes that info with the replacement joints. They differ slightly from Ford's.
On the tie rod ends, for '03 trucks it's 67 ft-lb (should be the same for your '05). The adjusting sleeve clamp bolts get 41 ft-lb (also an '03 spec). Can't find my '05 service manual right now.
