2003 F-Super Duty/Excursion Workshop Manual
SECTION 206-03: Front Disc Brake
SPECIFICATIONS
Code:
Torque Specifications
Description lb-ft
Disc brake caliper pin bolt 42
Front brake hose bolt 26
Front disc brake caliper anchor plate bolt
(Excursion, F-250, F-350) 166
SECTION 206-04: Rear Disc Brake
Description (lb/ft)
Disc brake caliper pin bolts — Excursion, F-250/F-350 with Ford and Dana axle = 27
Bleeder screw — Excursion, F-250/F-350 with Ford axle = 8
Rear wheel disc brake adapter bolts — Excursion, F-250/F-350 with Ford axle = 150
Rotor shield bolts — Excursion, F-250/F-350 with Ford axle = 8
Rotor-to-hub bolts = 94
Disc brake caliper anchor bolts = 128 lb/ft
Stone shield nuts = 46
