Im doing the front brakes on my truck and I cant find the torque specs anywhere. Caliper, mounting bracket, banjo bolt, etc. :read: Any one have the FS manual. I have a manual on CD that I got on ebay but I dont trust it.
Looks like the 22-26 is for the F150 light duty pin slider. That was a torque value taken off of a torque table in a manual that includes all Ford vans and trucks.
I would stay on the lower side of the range for the slide pins if it was me (and it was me on Tuesday). I did not use a torque wrench on anything then, I have been doing this stuff for a long time and just tightened until it "felt right". I still have to do my right side and will torque to spec to see how far off I was. There were no issues of consequence bobtail with new brakes on one side of the front but with a small load of hay behind (@4500 lbs) this morning brakes pull to the left side a bit.
The caliper slide bolts on my truck are 8mm, 85 foot lb
seems like too much for that size of bolt. 26 foot lb seems more like it to me.
Maybe the 85lb is for the pre 94 brakes I know they had a different style then.
Update.
I dove a little deeper into my FS cd and found out that the 85-100lb-ft is for a Super Duty caliper pin. I also found out that the F-150 uses a 8mm bolt to hold the caliper on as does the f-250 and f-350. I am going to use the 22-26lb-ft for these bolts on my truck.
