1 - 10 of 10 Posts
Hi: I have a tow haul problem with my 2008 F350 6.4L. It will not go into tow haul unless I tilt steering wheel up all the way and than slam it down and than it will engage. Than when I want to take it out, I have to shut off truck. Does any one have a wiring diagram and info on how to get at the wiring. Do I have to disarm Air Bag and pull Steering wheel? It has been like this for a year or more and no warranty on that part they tell me. Any help should help, [email protected] :ford::read:
Thanks Haakeye
You don't have to disarm the airbag or remove the wheel. The screws that hold the plastic steering column are located on the underside of the column. Remove the cover and you'll see the damaged wires where they enter the shift handle.
Either repair the wires or replace the shift handle. They are around $65 at a dealer.
wiring diagrams can be obtained from Helm,inc on their website
subscription is about $20 per month
Thanks Mark I tried to figure out wiring and switch and than bought a new lever and switch. works well now. I than took the old one apart even further and found the broken wire, I repaired that wire and now I have a spare unit.
Thanks again.:yesnod::jester:
Tow/Haul Problem
Hey Guys, I have the exact same problem. I'm trying to be fairly careful with removing the plastic covers. I don't want to damage them, but they seem to be really difficult to pull apart. Any suggestions???
Mark
(08' F-350 6.4L Auto)
tow haul problem
hello I have a 08 f250 ,it has gotten to the point where it will only go into tow haul if im in park .it used to engage while in drive and then only in neutral and now just park ,would this be the same wiring problem ,thanks
Yes, it would be the same.
Hi I have a 2006 f250 6.0 L 4x4 with the tow haul engaging on its own and causing the transmission gears to slam in I have changed the TTF sensor , the transmission range sensor , Ive checked the wire harness to the transmission and it looks good has anyone had this issue
Why did you change those unrelated sensors? They have nothing to do with tow/haul. Neither does the wiring harness to the transmission.
You should read this thread. The answer to what's wrong with yours is right there.
1 - 10 of 10 Posts
