2000 F250 Lariat
Have 2000 F250 Lariat with the standard plastic housed electric pan and tilt mirrors. Just purchased a camper to pull with it and the width of the standard mirrors is woefully insufficient.
I'm curious what others are using or what is specifically available as an alternative. Either complete replacement, clamp on extensions or other option. Opinions for such etc.
I gotta say, the mirrors on my new 22 are pretty awesome. Maybe they can be retrofitted somehow?
· Administrator
You can find aftermarket or (maybe OEM?) tow mirrors. Depending on the year, they should plug right in. You might need an adapter harness to plug in.
The other option is clamp on (which is what I use as I'm not fond of the Dumbo the elephant look of the tow mirrors) that you can remove when you're not towing.
Link
