Your not telling us much other on the truck,4x4 and cab size can change it slightly and so and rear gearing. So a SRW 350 CREW w/3:73 Is 11,900lbs hitch same for a 5er. A SRW 350 Crew w/4:10 is 12,500 hitch and 14,900 5er.
Thanks - that's exactly the info I needed - so for me the 4.10 gears are the best for the weight I would tow. I gather DRW would be a little higher? All the Info I get from the towing sites is centered around the diesel version - not the gas. Thanks again !
DRW will not get you more pulling weight, its actually rated less than above because the truck weighs more, but you do get another 300 or so pounds on payload.
Related Threads
The Diesel Stop
2.6M posts
211K members
Since 1999
