OK-here goes...
2000 Excursion XLT 7.3 4x4
I have no power at the trailer tow plug (haven't checked brake control signal).
Don't tow very often with it so I'm not sure how long this has been going on-I'm certain that last summer I had lights brakes and flashers though. Fuses all check out. The ground rings out as a strong connection with an ohm meter(from the plug pin back to the fram)-I expected that to be my problem! I took the factory plug apart and everything is in great shape. Also-the 12V trailer power feed has a known good relay and good fuse but nothing at the trailer plug either.
I had a pcm issue in the fall and had the underhood distribution box out a few times(to remove the computer plug bolt)-and relays in and out. Wondering if I could have left a connector loose(or inadvertently bumped something)?
Is there a relay that controls running lights and flashers for the plug (I don't have my Ford wiring diagram book with me so I'm not sure about a few things)?
I'm gonna do a visual under the truck tomorrow morning-I just don't want to start tearing things apart if I'm missing something simple...
Thoughts? Ideas? Thanks
