Hi guys
What is the trouble shooting procedure when the transfer case wont go into 4x4. I do not have a manual for this truck (2001) so I am at a loss as to which fuses to check.
Has anyone converted a eletric shift transfer case to a manual shift one
I am assuming you have the dial on the dash (electric shift) like in the photo below?
Discussion Starter #4
Yes I have the control on the dash.
The truck is a auto trans I have disconnected and blocked the auto hubs. the 4x4 light on the dash flashes on when the key is turned on then goes out.
I here nothing from the solinoids or the shift contrlo motor in the transfer case.
Can you check for DTC Codes?
