Smokey, I've just changed fluid in my 01 F350.
I had some flow through the bypass valve which I caught in a second bucket.
I know my cooler is clean, so I don't think a clogged cooler is the problem.
Air temp this morn was 95 deg, so cold is not a problem...(I live in Waco, TX)
I just returned from a lengthy trip through Wyoming and Colorado.
I had considerable trans heat problems...it would get around 195 to 200. I pulled over, let it cool several times.
I've never had an overheat problem before while pulling my 5th wheel camper, in the same areas.
Could it be that the bypass is weak letting the fluid bypass the cooler?
It's a BTS tranny.
It's a BTS tranny.
