1992 f250 7.3 engine with e4od tranny.truck has been running great.parked it friday after work i went to go to work monday and the truck started but wont move in drive or reverse.the tranny fluid is way up on the dipstick.what should i be looking for.
Broken flex plate, or a broken pump are the most likely. When the engine is running see if the torque converter is turning. Do this with the trans in park!
if the pump stopped working does the tranny have to come out or can i replace the pump without taking out the tranny.
Transmission has to come out to replace the pump.
