On the way home today i heard a little squeak sounded kinda like a sucking sound. it only lasted for a few seconds, then stopped. drove another five miles and started to hear a grinding noise so i let off the throttle and coasted down to 40mph, i pushed the gas a little, seemed fine for about 5 seconds same noise, did the same thing again and again at lower speeds (i think for each gear). anyway had to get towed home. the forward gear clutch pack was replaced about 11k miles ago. now it won't move in forward or reverse and makes that same grinding noise. my father-in-thinks that it might be the input shaft.
He also thinks that maybe a vacuum line could have came loose i'll check that after i eat.
What do you guys think?
