My 06 F350 (SRW) will not go into 4 wheel drive with the hubs in auto, but will go into 4wd with the hubs locked. Anybody know what the problem may be?
Larry
Larry
X2. Check if your heater will only go to defrost. sure sign of a vacuum leak "somewhere".Sounds like you have a vacuum leak either in the auto hubs or in the line from the vacuum pump (on top of the right inner fender) or your vacuum pump is bad.
MY F250 WAS DOING THE SAME. SOME TYPE OF VACUUM LEAK. DEALER FIXED IT.:thumbsup:My 06 F350 (SRW) will not go into 4 wheel drive with the hubs in auto, but will go into 4wd with the hubs locked. Anybody know what the problem may be?
Larry
