Guys, I have a 2000 7.3 with 220k on it if I drive it daily I have no issues if I park it and let it sit on the third day I see transmission fluid on the ground does anyone know what causes this?
You need to narrow down where the fluid is coming from. Give it a good cleaning and then check in a few days. Use a white paper towel and check around the pan gasket, rear seal, shifter shaft, and front seal area. Also, remember the engine valley drains out the back of the engine and drains through the torque converter cover.
