Automatic transmission makes several clunks as it is coming to a stop. Trying to start from a stop it will rev and make a grinding noise and will only go when you put it into L2.
Im exhausting every possibility before going to a shop to drop thousands of dollars I don't have.
After reading old threads for a week the only possible scenarios that I can hope for are a shifter cable adjustment, or a plugged up cooler.
I just received an Edge Evolution I bought to read the trouble codes. No transmission related trouble codes found.
The Edge Evolution gives a real time readout of the transmission pressure. I have no idea what correct pressure is though. It will read 5 at idle and 30ish under light acceleration. What should normal pressure be?
