Hello everyone my truck has an e4OD and about 3 weeks ago I replaced the transfer case because it crapped out and then about a week after my OD light started flashing and shifts hard from park to drive and from first to second, I know when it flashes because it's in limp mode and if I unhook my batteries and hook then back up to clear the code it'll drive perfectly fine and won't shift hard and won't flash, I replaced my fipl sensor and tachometer but really only had to replace tach and still no luck my fipl is adjusted correctly and my transmission has plenty of fluid, also the OD light flashes all the time when it comes on even in park, has anyone else had a problem like this? Any help is appreciated
