No, the early C6s use a vacuum modulator. Later ones (like my '93) use a kickdown cable. I'm not sure when the change occurred.There has to be some way that it controls vacuum...
Ford designed both, and doesn't seem to agree with your opinion. Historical statistics also disagree with you.The C6 is...better than the newer electronic ones.
The C6 is still easier to work on, has fewer things to go wrong, and doesn't depend on any electronics to operate. In my book that makes the C6 the better transmission. My preference, however, is the ZF5 manual transmission.Ford designed both, and doesn't seem to agree with your opinion. Historical statistics also disagree with you.
