I recently installed guages on my truck. (2000 f250) For the trans temp gauge I installed the reader through the test port on the drivers side of the transmission. On the highway I'm usually between 140-160 but in the city it can climb up into 180. I live in Miami so when I say city I mean stop, go for a couple blocks and stop again. Ambient temperature has been anywhere from 85-95 this past week. I also have a hard shift from first to second it kinda slams into gear and maybe that's what's causing the higher temps. Any input would be helpful. THANKS !!
You don't have higher temps. Anything from 60-100°F above ambient is normal for the 4R100 trans.
Cool. I was wondering cause I have been looking up normal temps and everyone reports higher temps on the highway than in the city.
Then everyone is wrong. You'll get higher temps in the city, not the highway.
One thing I can add is that around town it takes my transmission a long time to reach the same temps as on the highway. So if I drive say 20 min in town then get on the freeway it will seem like the freeway temps are higher because operating temp is reached in just a few minutes. But if I drive around the city for a couple of hours I will reach those higher temps.
With a 6.0 cooler 150 to 180 is the normal operation temp
