Bought the truck in 05 and had the transmission flushed out right away and BANG, the dreaded blinking OD light. Ford at the time said it was a slip code and cleared it. It happens again every once in a while, and though I should not, I clear it via detaching the battery. It has happened twice this month and I have decided to finally do right. I want to get it checked for the code, but no one around for at least 3 more days to do it and it is my truck I need to drive. Is there a way to pull the code myself? I have a code puller but it will not pull tranny codes. Aside from a repair facility and the tool, is there another way to do it? Just as a background; it happens when under a load accelerating up a hill in cruise generally. There does not seem to be a slip, the OD light just comes on. I have noticed at the 3rd to 4th or overdrive, (not sure about the sequence) some times it stutters slightly if you are accelerating slowly. Has good fluid. I changed it out as well as the torque converter and check it frequently. No speedometer issues. The rear light was out when I first got it and it slipped. I have heard that may be related?? Any information? Thanks, TOM
