1 - 14 of 14 Posts
I changed number 2 4 6 8 injector and now I have a hard shift to tow haul light is staying on but I do remember I never disconnected the battery and the alternator wire hit and Spark twice
Get the codes read. The places that read codes free cannot read these codes. Forscan is a good way, or a good independent shop, or a Ford dealer.
P700,p766, and p2703 are the codes
And I forgot to mention that I didn't disconnect the battery and the alternator wire hit and spark about 3 times,iv eww check all the fuses and they seem to be good but fuse 31 has no power at all all
How does a fuse seem to be good? It is either good or not. Did you check each one for continuity, or just look at them? If you just looked, you have no idea if they are good or not.
P0700 means the PCM recognizes SOMETHING is wrong, but can't narrow it down. P0766 means shift solenoid D is mechanically stuck. P2703 means the clutch controlled by shift solenoid D didn't apply like it should because the solenoid is stuck.
I think the first thing to do (after fixing the fuse problem) is to clear the codes and see if they come back.
I don't have a diagram to know what that fuse controls.
I'm just a simpleton from Saskatchewan so I miss a lot of things but if you've got a blown fuse, replace it. Then its no longer blown and no longer relevant what it may control. Unless of course it promptly fails again, in which it becomes relevant. Right now its just a blown fuse with no particular relevance to anything.
You have an 03 or early 04 6.0L?
Discussion Starter · #11 ·
No I have no blown fuses
Do you have a manual that you can use to post up what that fuse is for (as requested earlier)?
My 03 reference (unofficial source) says it is for the transmission Range Sensor. Sure would be better for you to answer that question.
Discussion Starter · #14 ·
Yes it's a transmission range sensor but it has no power there whatsoever
1 - 14 of 14 Posts
