transmission shudder, is that like when you are driving a standard trans with a grabby clutch in between shifts or just a bad driver?
If so, can flushing out the old trans fluid help to eliminate it?
I have a early 99 with 168k on the original trans. It shifts great when unloaded, but it will shudder (I guess) once in a while when pulling.
normal temp unloaded: 70* above ambient
normal temp towing 7k - 18k lbs: 80-90* above ambient
never seen temps above 195*
