Hey guys,
I've got a friend having some trouble with his 98 2500 with a Cummins. Here is his problem. When downshifting (manual tranny), the engine will sometimes shut down. When he realizes it's shut down, he pops the clutch and the motor fires right back up. This is alos accompanied by some codes, P0121 and P0234. One is realated to the wastegate not functioning and the other has to do with the map and TPS not communicated properly. Does this mean that on a downshift, the manifold pressure gets too high because of a malfunctioning wastegate and the engine shuts it self down? I don't know anything about Cummins so any help would be appreciated
Thank you
Thank you
