Truck has been running fine. 129,000 miles, 1999 F250, 7.3, 6-speed.
Started truck to go about 100 yards to pick up my laundry. Started fine, then became unresponsive to throttle, then started lopey/knocking idle than died.
Will not restart and run. Will kick over, but then immediately cut out.
No SES light. No codes that are popping on my cheap code reader.
Fuel pump is running, I can feel it hum when I put my hand on it. When I turn the water drain valve, I get a healthy stream of fuel.
I put a known good CPS in it just as a hunch. Nothing. Just turns over, may start and run for 1-2 seconds, then die.
Will not stay running. Checked relays/fuses, no popped fuses. Played "musical relays" just to see if that would get it.
I'm out of ideas. My "Childrens" (CHILTONs) manual is not helping much either.
Truck is stock, save a straight pipe in place of muffler.
