Re: truck not charging trailer battery
I dont know for sure what post it gets it from. But I would go to the harness under the truck bed and check that connection. If the post on the 7 pin doesnt work,, flow backwards looking for the problem.. AFTER your POSITIVE you have checked all the correct fuses. (I Only reiterate this because I spent a good TWO hours looking for the reason my left turn on my trailer would NOT WORK, tracing wires all the way forward in the harness,, checking and rechecking all the other factory connections. Thinking I may have drilled into that wire with one of my mods..or something./ubbthreads/images/graemlins/eek.gif ,and it did turn out to be a fuse under the hood. /ubbthreads/images/graemlins/rolleyes.gif /ubbthreads/images/graemlins/phoney.gif)
Which resulted in a mixed emotion of relief and exhasperation!!! /ubbthreads/images/graemlins/biggrin.gif
I can try to find out which pin it is, but you obviously should have 12V to everything back there while that is working,,ie... Backup lights, turns, brake, tail, but I IMAGINE you would have something like 14v while the truck is RUNNING going to the battery? Just like the trucks batts get. (Still should have something there,,,,12v at LEAST.)
