Hey all,
I will try to describe this the best I can. I have a 2000 7.3L crew cab short bed 4x4 auto with 145,000 on it. The truck was chiped, but I removed the chip as soon as i noticed this problem. Please note that removing the chip really didn't cure the problem at all. I start the truck and she fires up fine, idles fine, and accelerates fine, but recently (past 4 days) the truck will randomly die when I either slow down at a stop sign or red light, or when I go to make a turn. It is not a re accuring thing at every stop or turn, but it has happend enough to notice there is a problem. I notice that when the truck dies that the bettery light stay lit, but this happend at night and the lights stayed on even though the truck was off. The way the truck dies it feels the same a it does when you turn the key to shut the truck off. In other words, the truck does not spudder to a stop, it litterally shuts off completely. Now for the re-start. I put the truck in park and turn the key all the lights sounds and everything work, the WTS light shuts off and I fire the truck up no problems what so ever. I am truly stumped as to what this could be. I noticed when I had some audio equiptment installed that there we some wire leading from the fuse panel that had been jammed into a fuse slot underneath the fuse, but I pulled the wire and fixed the fuse jack, so I am almost certain this has nothing to do with a fuse because all my lights and everything work fine when I go to restart it. Again the only thing i noticed was the battery light lights up when the truck dies. i though it might have been my chip so i took it out, but the problem still occurs. I replaced the batteries like 1 month ago. Bad Fuel? CPS? Fuel Filter? I am stumped on this one, any ideas?
