At work, I'm working on an '00 f-350. Afteer letting it sit for a few days, it would hardly start. When it finally went it was missing really bad. After I drove it for a little bit, it cleard up and seem to run okay. Any ideas? It was in the upper 80s today, so cold weather definitely is not to blame.
How many miles does the truck have? I just fixed a similar problem with my truck, I needed injectors...but it could be a number of things,what have you checked so far? /ubbthreads/images/graemlins/confused.gif
It has around 115k. I guess the guy bought it as a flood truck. The tech before checked the injectors and put new o-rings on them. This is the first I've worked on the truck. I've only worked at this place for a little over 2 weeks. At first I suspected the valve cover gasket, but since the problem went away when it got warm, I knew that wasn't it.
