1 - 10 of 10 Posts
Anyone running this? Curious about the feedback on it. Wondering if it would go nicely with stage 2 swamp injectors and adrinaline hpop.
Does it give this the stock transmission bad shifts like the edge evo? Probably main concern.
Looking for a tune. Using the edge evo cts as a monitor.
Yes you can use the chip and edge as monitor.
Lots of people use the ts and love it. Make sure to get custom tune and you'll be fine. Well ever tuner you chose it will be way better than the tune from the edge (what i eard)
I run the hydra with php tune and love it
Did you consider the hydra?
Swamps sells a ts chip with their tunes on it for their injectors
i ran the edge evo for 4 yrs and broke down and got the ts 6pos chip and use the edge for monitor purpose now. i can say i am not overly impressed, if i had it to do again i would not get it. also my mpg dropped 4 to 5 miles per gallon in any setting but stock.
Ts chips with standard tunes aren't anything special. The tunes on the ts and edge were written in 2002-2004 lol.
And just running ts tunes doesn't drop your mpg. Unless you drive with your foot to the floor everywhere blowing smoke.
Contact [email protected], a custom tuned ts chip is 250 for a stock truck.
But it will cost you a little more since you don't have stock injectors.
And if you want you can just get a pcm flash from dp tuner with like a 60 hp tow or daily tune. That might be your best bet.
My problem with aftermarket injectors plus it hasn't been over 20 outside in a month iv been get 13-14 mpg. I'm guessing it because I'm running on stock mix with how cold it is. Plus the fact I always pre heat my truck never put it in drive until it's at at least 115. I feel with a custom tune I'll see alot better results from these injectors. I ran it with the race tune on edge for a week or two, I saw no less than 18mpg.
what are you a novice blue 99 drive my truck same as with edge, dropped mpg thats the way it is ts chip for sale 2 bucks.
profisher 13-14 is pretty normal mpg for split shot injectors and winter fuel.
If you want more than one custom tune contact php, gearhead, swamps, dp tuner.
I've been running a ts chip with php tunes for 4 years with no mpg drop. I average 15-16.
And my truck came with an edge evolution, when I ran it I didn't notice a drop in mpgs either. But I don't have an aggressive driving style.
1 - 10 of 10 Posts
