2003-2007 F-super Duty/2003-2005 Excursion/2004-2008 E-series - Cooling System Diagnostics - Oil In Engine Coolant - 6.0l
2003-2007 F-super Duty, 2003-2005 Excursion And 2004-2008 E-series Vehicles Equipped With A 6.0l Engine, May Exhibit Oil In Coolant, Crank/no Start, Lack Of Power, And Coolant Leak. The Coolant Leak Creates A Low Coolant Condition Which May Cause The Engine To Overheat Or No Cabin Heat Condition. The Condition Typically Occurs When Operating The Vehicle Under A Load Such As Trailer Towing, Uphill Driving, Or Both. Prior To Making Any Repairs, Verify The Coolant Level Is Not Overfull. The New Coolant Fill Level Is At The "min" Line Of The Degas Bottle When Cold. Overfilled Coolant Levels Will Cause Coolant To Vent From The Degas Bottle Cap. If The Degas Bottle Is Not Overfull, And Is Still Venting Out Coolant, Refer To The Tsb Service Procedure.
