Anything else??? What all has been done?..just what you mentioned in the post? Fill out your signature. You need a bigger exhaust, intake, gauges....to start with.is there anything else i need to do with a gtp38r and 238cc hybrids? i have the dp chip for single shot injectors.
also, i changed my fuel filter today, and it looks like there was motor oil in the bottom of the bowl. any ideas on what that could be?
im going to do the regulated return when i do injectorsAny fuel system mods? Regulated return or bowl delete with higher flow pump and filter?
VS's?You better get studs and VS's esp with a 38r, the back pressure will be high.
Fuel mods..good idea..
