What kind of numbers are you guys pushing with your stock turbo? Does this increase when you unplug the wastegate? For some reason I can't seem to get above 19 psi with or without the wastegate unplugged. The problem is when I put my chip in which is a TS four position chip, I am running some really hot EGT's and I think this is due to the lack of boost. Even under the lowest setting of 50, I can still hit 1200+ easily even on flat land.
Also I have blown off the EBPV three times and have fixed and replaced the clip but what could this be caused by?
Thanks for your help, Jared
Check all your boots. Especially the 2 orange ones under the Y pipe. Sounds like you have a leak somewhere.
