Yeah, Heath, I should have said "high octane-rating", but I figured we all know what I meant. Still, it's good to point out just what "octane" is: a chemical that is rarely used outside of testing labs. It just provides a handy reference; "100" on a scale.
Diesels burn clean, in terms of tailpipe emissions of unburned hydrocarbons (HC) and incompletely burned hydrocarbons (CO). So clean, that for years and years the EPA did not test diesels at all. Then, when passenger diesels began being popular and in poor condition, many municipalites went to opacity (smoke) testing of diesels only. It's only been recently that diesels needed more emission controls to meet escalating clean air stds, but in comparison to gasoline, diesel was a LOT cleaner in HC & CO at the tailpipe, for many years. Notice I'm leaving aside polycyclic aromatics and soot, but that's another topic altogether.
Having low HC & CO means that there is not, under normal conditions, a lot of unburned fuel in the combustion chamber to benefit from more air. Put more air in, and all you get is cooler parts, reduced thermal stress, and that's about it. Modern diesels don't have intake throttles (though older diesels did, notably the MB 200D and older, and the Nissan SDx series), so they enjoy greater efficiency WRT the pumping losses (add'l HP required to just move the air in and out of the engine) than gasoline engines, but adding a turbo recovers some waste energy from the exhaust (heat is exchanged for rotary motion) and lets the engine benefit from even lower pumping losses, so there's a bit of HP to pick up there, but we're not talking double-digits.
My point is, there isn't any add'l fuel to burn in an engine to which a turbo has been added, unless the engine was over-fuelled to begin with. Because diesels squirt the fuel into the middle of hot air, very little reaches the relatively cool cylinder wall or combustion chamber surfaces to be quenched and prevented from burning completely, which is why diesels are so much cleaner in HC & CO than gas engines that always have fuel sitting next to cooler surfaces and get swept out the exhaust without burning -- to get oxidized the catalytic converter instead.
But I agree that turbocharging should be on all engines. Why isn't it?
