Mid driving I heard a noise and the truck lost it's get up and go. It started driving like a big rig, taking forever to accelerate.
I looked up similar problems on this forum and here's everything I've tried... (oh and as I tried things, the error codes changed. I've gotten p1260 and p1248, p1000 and p0236)
Checked all the boots, they're connected properly
Replaced the Map Sensor (this seemed to make it a little less gutless, but still didn't feel like turbo kicking in)
Ordered a refurbished turbo and started taking things apart to replace it...
Found that the airfilter had partly collapsed and was blocking the intake, so I replaced the filter and buttoned things back up, hoping that was all. Didn't fix the problem.
Took the the turbo completely off (pain in the neck by the way) only to find that the turbo guys sent me an E-series thinking that was for our Excursion, but it wasn't, I need an F-series, grrrr - really people, this is your job...)
Needed to be able to drive the truck (although slowly) until correct part came, so I put it all back together again, here's the tricky part - no more error code (I've gotten a myriad of different codes throughout this whole process) and the turbo seems to be working.
It's not working at 100%, however, sometimes I give it gas and get nothing, but mostly the turbo works. Well we're going camping next weekend and I needed to know if we'd be able to pull our trailer up the hills to the mountains, so I hooked it up and went for a test drive and can tell it's just not going to have the power I need.
So that's the story (long one, sorry) I just don't know if it is the turbo that needs to be replaced, or if it could be something else and why it's not giving me an error code now and seems to be semi-working.
Thoughts, or ideas would be greatly appreciated, Thanks!
