turbo rebuild kit
6.3K views 3 replies 2 participants last post by  fordboyyfm
#1 ·
Ive heard international makes rebuild kits for these but the dealer isnt any help since its a ford. does anyone know the part number for the kit from international. ive looked all over for them and i cant find them, all i really need is the oil seal on the turbine side its seaping a little bit.
#2 ·
Are talking about the oil feed line? you can find that and a lot of other parts on ebay if you search ford 6.0 or 6.0 powerstroke if it is the oil feed line connects to the top i have that part number. ebay for $10.
#3 ·
I found these items on ebay # 360258088614 called turbo gasket seal kit $3.99
And #190309392712 called turbo overhall kit $199.
At least you can see if that is what you need they show the ford part numbers.
It may have the oil seal on the turbine side that your looking for.
#4 ·
no. i work at ford, they dont have what i need you have to buy the whole center section. ive looked all over the internet only thing i found is from garret but its going to be a pain to order it you need a tax id. i want the seal that goes on the shaft. the kit should come with bearings and seals
