I have a spare Egt Gauge sitting around and i want to make use of it. i know to read actual EGT's i have my Attitude Moniter Tapped into my Exhaust manifold. so i was wondering if i tapped the down pipe i should be reading about what the Turbo's running at temp wise Right? or is it cooler than the gas coming out of it because theres Oil running through it?
There is no reason to measure the temps post turbo. The only thing that matters is pre-turbo.. And the pre-turbo value is what your turbo is seeing.. Post would just let you know what is going out the pipe...
