I heard a whistling while idling my 05. The bellow on the turbo y-pipe on the right down pipe is cracked. Does anyone make a replacement? I went ahead and bought the lower pipe also, which I will modify again. Also, has anyone noticed the factory replacement up pipe for the right side DOES NOT have the scoop in it anymore, or mine doesn't anyway.
If no one makes an aftermarket y-pipe, can you modify it so it won't braek again? I have heard of cutting out the bellows and welding a pipe in its place. But, how do you get the pipe in place? The pipe has to constrict then expand once you tighten the bolts. I guess you could loosen the manifolds enough to get them in, then tighten them back up.
Any help is appreciated.
Aftermarket "Y" pipe
Neighbor ... try Ford Products
I am new here and need to replace the Y pipe on my recently purchased 2004 F250 Harley Davidson. I bought the truck assuming that the thing was typical Ford equipment like what I've been driving all of my life. Very stupid of me not to check it out first. Anyway ...
I know absolutely nothing about this Liberator Performance Y pipe, but am thinking that the OE unit isn't working so maybe trying this wouldn't hurt.
hope this helps .... ron :)
The up pipe is avalible in the aftermarket with out the scoop. With a solid pipe you can loosen the turbo to get it to mate up then tighten the turbo back up
