This may sound a lil’ ignorant, but can someone please tell me where I can find the turn signal flasher relay on a 2015 F250? Thanks y’all!
Charlie
There is no flasher/relay that is serviceable. The BCM controls the flashing via the CAN Bus as it appears in the wiring diagrams.
What is your problem?
Not really a problem, I’m just wanting to change over to LED, and I was told for turn signals that I’ll need to change the turn signal relay to prevent the “rapid flashing” of the lights. I am guess this is wrong for the newer models?
No, you need to have the LED out status changed in the IPC. When you install LED's it causes the blinker to "hyper flash" from the bulb out circuitry. You will need to get the dealer to change the setting or FORScan.
