1 - 11 of 11 Posts
I have a 2003 F350 Super Duty Lariat and my turn signals, hazards and brake lights keep turning off. The console lights as well as the exterior lights. I checked the fuse and it was burnt, so I put in a new one and it all worked, I pulled out of my stall, reversed, pulled back out and turned onto the road and it burnt out again. I replaced the fuse, once again, and it did the same thing. Does anyone know if it's wiring, the switch itself or the hazards? I don't want to take it in, because that would be a waste of money if it's a simple fix, I just need a general area to start.
My first guess would be a short in your trailer harness connector in the back of the truck.
This could be the cause, even if I don't use a trailer?
Wires could be damaged. I had one on my f150 that got hot and shorted out. Also had one the dog chewed up. You have a shorted wire somewhere. I would start there because its exposed.
Yup. In a sense "use it or lose it."
If you're using it, you will see the condition of it frequently. Not using it, you will never inspect it.
The fuse your changing is it F2.27?
From the wiring diagram I wouldn't assume the trailer wiring.
It was either on these forums or somewhere else but a person had almost the same problem and traced it back to a socket on the lights being bad.
I'm pretty sure all of the 99+ trucks have separate isolated circuits for the TT wiring. So no point looking there IF that's the case. If turning on either signal fries the fuse, I don't think it could be a light socket, if only one or the other signal blows it, then yes, my bet is on a lights socket issue or harness problem to the socket.
Discussion Starter · #9 ·
I have no idea, I just know it's the 20 amp fuse in the #18 slot
Discussion Starter · #11 ·
It's weird, when I'm in park, hazards work, blinkers work, brake light works but once I drive or turn, it seems that there's something in the steering column perhaps, that is making it burn.
1 - 11 of 11 Posts
