I am trying to install compound twin trubos on my '94 F350 and I also have an intercooler form a 6.0 that is installed but just needs plumbed in. I was wondering if any one has a set up like this or knows of any pictures or has ideas on how to do this because the second turbo has to mount right above the passenger valve cover so there'd be exhaust running between the turbos the new down pipe from the second turbo (I think I'm just going to run it out through the inner fender and down the outside of the frame) and the intercooler pipe going to the Y pipe all right there in the same place and I don't know how to make it all fit especially with an intercooler pipe in there because I probably don't want it too close to either of the exhaust pipes.
I was also wondering on how much boost and RPMs I'll be able to run without hurting the block too bad until I can afford a girdle.
Thanks for any help you can offer,
Alex
Alex
