1 - 9 of 9 Posts
Ok, so changing out thermostat housing, I anti-seized the bolts that came in billet housing, tourqed them to 15ft/lbs and twisted one off. End to a long day, was able to salvage by backing out before complete separation. I have heard anti-seize can change tourque reading but what bolt can't take 15. I may have done something wrong but not sure. I have had this happen on a bolt while changing diff cover thought it was bad quality bolt but maybe I suk as mechanic
There are a lot of bolts that can't take 15 lb-ft. You've identified two of them. And anti-sieze is a lubricant. A lubricated bolt at 15 lb-ft is significantly tighter than one without lube.
I put a tiny bit of anti-seize on mine and had no trouble, 3 times now. Have you had your torque wrench calibrated lately? Also keep in mind if you are using a big torque wrench that goes to a high number your accuracy range will be broader and different at lower values.
As a side note Dieselsite only recommends 100-110 inch pounds on their billit housing, which is less than 10 ft lbs. Billet Aluminum Thermostat Housing | Ford 7.3L Powerstroke | Diesel Site
This is what I am trying to say about a torque wrench that goes to a high value when used at a low value. From the StangTV site written by a torque wrench expert. That is why it is best to use a very small torque wrench like the ones for inch lbs on small fasteners. (read the attached thumbnail)
Did not see any recomendation from them in on torque values would of helped. The stock bolt was 17 ft/lbs but with thicker housing can see a lesser value. Lesson number? Lost count already
That may have helped but I still suspect the lubrication combined with an inaccurate torque wrench may be the problem.
How many times have the bolts been reused? That makes a difference as well, because the bolts are stretched just a bit each time they're tightened. It's similar to bending a piece of wire multiple times till it breaks. As was said, anti-seize makes the bolts tighter than they would be if torqued dry. The torque spec for the water pump bolts is 18 ft-lb and those bolts are one size larger than the thermostat bolts, so 15 ft lb is much larger when compared to the difference in cross section area of the bolts.
They were brand new bolts, will avoid anti-sieve till absolutely needed. Reset new bolts to 10 ft/lbs and more bed on to next project.
Or, you can do the RT mod- get 3 stainless grade 8 bolts about 10mm longer than you need. Cut the heads off and Loctite the studs into the water pump. Use stainless nuts on your housing. Never worry about breaking a bolt off again.
1 - 9 of 9 Posts
